After a quick google search, the quick answer is that the limitation is with the charger not your vehicle.
The longer answer is that the Freewire DCFC's are A) made for locations where grid power is limited and B) labeled incorrectly (in my opinion).
From the Freewire website, here is their highest powered DCFC:
Boost Charger 200
The Boost 200. It says it can provide 200kW, or 100kW split between 2 cars.
But the reality is that is just a number on the spec sheet.
Because if you download the technical specifications sheet and look at the electrical specifications section, you'll see that it can only output 125 amps continuous.
Compare this to a 150kW Electrify America station which outputs 350A continuously. Or an EA 300kW station which can output 500A continuously.
The nominal voltage of our XC40's is a little over 400V. So when you plug into an EA 150kW station, that's how your seeing those 150kW charging speeds:
150,000W/350A = 428V.
The Freewire Boost Charger 200 would only ever output 200kW to a car with a battery pack who's voltage is 1000V!
The highest voltage car on the market today is the Lucid Air which has a nominal voltage of 920V.
Even according to their data sheet their chargers can only output up to 950V DC.
So by my math the highest sustained charging speeds you could theoretically see on this charger would be ~118kW, far from their claimed 200kW.
950Vx125A
So my guess is that they have a boost function, where you get higher speeds for a set amount of time before the equipment starts to heat up and derate.
Or maybe they boost the grid power using the internal 160kW of batteries to get to the higher speeds.
It says it has 160kW worth of batteries, but this is mainly to reduce demand charges typical of other high powered EV chargers.
Could you provide the exact station you used on Plugshare?
A quick search shows only one Shell DCFC Recharge location in SoCal, and that one seems to be only 50kW. Maybe you were using a new one that hasn't made the map yet?
